Publishing a Workbook to a Folder
Publishes a workbook to a specific folder.
Option |
Description |
-w, --workbook |
The workbook file to publish. Syntax example: java -jar pcli.jar publish -w "workbook" -u "http://username:password@host:port/app_name/" |
-u, --url |
URL to Panopticon Real Time, syntax: java -jar pcli.jar publish -w "workbook" -d -u “http://username:password@host:port/app_name/” NOTE: The username in the -u command must have permission to the folder. Just being in the list of Administrators is not enough. |
-n, --name |
Publish workbook to a folder on the server with a different name. Syntax example: java -jar pcli.jar publish -w "workbook" -d -u "http://username:password@host:port/app_name/" -n “folder\name” |
-d, --dataFiles |
Find and upload data files used by workbook. |
Command example: java -jar pcli.jar publish -w "E:\Temp\How to Actons.exw" -u "http://username:password123@localhost:8080/panopticon" -n "test\How to Actions.exw"
