Schemify
Updates workbook data tables with missing schema information.
Option |
Description |
--dd, --data-directory |
Data directory path. Syntax example: java -jar pcli.jar schemify -wd "workbook directory" -od "output directory" –dd "C:\Users\Public\Documents\Datawatch Desktop\Data" |
-D |
Default parameter. This can be supplied either by using: -dp command to pass the path to Parameters.json which is the default parameter file Syntax example: java -jar pcli.jar schemify -w "workbook path" -o "output path" -l "license file path" -dp "default parameters file" -D switch to specify parameters Syntax example: java -jar pcli.jar schemify -w "workbook path" -o "output path" -l "license file path" -D "parameter=value" |
-od, --output-directory |
Output directory path. Syntax example: java -jar pcli.jar schemify -wd "workbook directory" -od "C:\Users\Public\Documents\Datawatch Desktop\NewWorkbooks" –dd "data directory" |
-w, --workbook |
Workbook to schemify. |
-l, --license-file |
License file path. Syntax example: java -jar pcli.jar schemify -wd "workbook path" -o "output path" -l "C:\vizserverdata\PanopticonLicense.xml" |
-wd, --workbook-directory |
Directory of the workbooks to schemify. |
-o, --output |
Output path. |
