Using SAML Through OpenAM
To enable roles mapping with OpenAM, perform the following configuration in the IdP:
1. Add value isMemberOf to the LDAP User Attributes list in your Data Store.
2. Add value isMemberOf to the attributes mapping in your IdP configuration.
3. Set authentication.saml.assertion.roles=isMemberOf in the Panopticon.properties.
