Set Client Automatic Reconnection to the Server when Disconnected
When the client loses connection to the server, by default, it will no longer attempt to automatically reconnect to the server.
A notification message displays such as below. Clicking the Reconnect link will attempt to reconnect to the server.
The AppData folder of Panopticon Real Time has a subfolder named JavaScriptConfiguration which contains the file named workbook.json.
Below is an example default content of a \JavaScriptConfiguration\workbook.json file:
"baseUrl" : "..",
"forceClientSelectionHandling" : true,
"startUrl" : "../",
"subscriptionCompression" : true,
"dataLoading" : {
"transport" : "websocket"
"webGlEnabled" : true,
"pdfMultiplePagesEnabled" : true
To set automatic reconnection to the server, add the following parameter in the JavaScriptConfiguration\workbook.json file:
"automaticReconnectOnServerDisconnect" : true,
NOTE |
After each change in the workbook.json file, the Panopticon application must be restarted.
A notification message displays such as below. Connection to server lost: attempting to reconnect…
