Converting Timestamp to/from Integer
Allows you to convert Timestamp values to/from Integer which include the following examples:
q from posix to timestamp
q from posixmillis to timestamp
q from timestamp to posix
q from timestamp to posixmillis
The conversion uses the expression: to([typename],[expression],[format]
Examples:
q to(int, timefieldname, 'POSIX')
q to(time, intfieldname, 'POSIX')
