Supported Operators and Calculation Functions
This section lists the supported operators and calculation functions in Panopticon Streams.
NOTE |
Panopticon Streams supports nullability where: · a field may or may not allow null/empty/missing/NA values · functions or operators may or may not allow null arguments (e.g., you can’t divide seven by null)
Supported Operators
These are typically the operators that are used to create aggregation operator and calculation operator expressions.
Operator |
Name |
Description |
Example |
Nullability |
Logical NOT |
! boolean Reverse arguments or results. Parameter: · boolean – A value of logical expression that can be evaluated as TRUE or FALSE. |
Not Equal To |
Tests if one value is not equals to another. |
12.3 != 47.11 = true |
a |
Modulo |
number % divisor Gets the remainder from division. Parameters: · number – The Number to be divided. · divisor – The number to divide with. |
17 % 5 = 2 |
Logical AND |
Returns true only if both the conditions return true. |
(7 > 5)&&(3 < 8) = true |
Multiplication |
Multiply |
9 * 5 = 45 |
Addition |
Adds two numbers or joins two or more text strings to produce a single piece of text. |
47.11 + 9.7 = 56.81 |
Subtraction |
Subsctracts two numbers. |
47 – 11 = 36 |
Division |
number / divisor Parameters: · number – The number to be divided. · divisor – The number to divide with. |
11 / 5 = 2 |
Less than |
Tests if one value is less (smaller) than another. |
4 < 7 = true |
Less Than or Equal To |
Tests if one value is less than or equal to another. |
7 <= 4 = false |
Equal To |
Tests if one value is equals to another. |
9 == 5 = false |
a |
Greater Than |
Tests if one value is greater (larger) than another. |
7 > 4 = true |
Greater Than or Equal To |
Tests if one value is greater or equal to another. |
7 >= 4 = true |
Ternary IF |
Provides branching capability. If condition is true, then it returns exprIfTrue, else returns exprIfFalse. condition ? exprIfTrue : exprIfFalse Parameters: · condition – A value or logical expression that can be evaluated as true or false. · exprIfTrue – The value to return when condition evaluates to true. · exprIfFalse - The value to return when condition evaluates to false. |
a |
Exponentiation |
Get the exponential value of the number. |
(2.0) ^ 7.0 = 128.0 |
like |
Like |
Tests if the pattern exists in the text. |
‘olle’ like pattern(‘.ll.’) = true |
Logical OR |
Returns true if any of the conditions return true. |
(7 > 5) || (3 > 8) = true |
Negation |
Negation of the number. |
-(1 + 2 ) = -3 |
Positivity |
Positivity of the number. |
Cast Operator |
Explicit data type conversion. Valid casts are: · ‘int’ · ‘real’ · ‘text’ · ‘time’ · ‘bool’ |
(int)sqr(Numeric1) |
