Supported Calculation Functions
Operator |
Name |
Description |
Example |
Nullability |
abs |
Absolute Value |
abs(number) Find the absolute value of a number. Parameter: · number – The number to get the absolute number of. |
abs(-47.11) = 47.11 |
array |
Array |
array(size,value) Create an array of specified size and initialize with the given value. Parameters: · size – Size of the array. · value – Array elements. |
array(5, 1.1) |
a |
atan |
Arc Tangent |
atan(ordinate, abscissa) Get the inverse tangent of a number. Parameters: · ordinate – The ordinate coordinate. · abscissa – The abscissa coordinate (optional). |
atan(1.0) = 0.785398 |
ceil |
Ceiling |
ceil(number) Returns the smallest double value that is greater than or equal to the argument and is equal to a mathematical integer. Parameter: · number – The number to get the ceiling value of. |
ceil(4.7) = 5.0 |
clock |
Clock |
Returns the current system Date/Time value. |
clock() |
concat |
Concatenate |
concat(text1,text2) Joins two text values. Parameters: · text1 – First text to join. · text2 – Second text to join. |
concat(‘olle’,’pelle’) = ‘olle pelle’ |
cos |
Cosine |
cos(number) The natural logarithm (base e) of a real value. Parameter: · number – A number to take the natural logarithm of . |
cos(0.0) = 1.0 |
cosh |
Hyperbolic Cosine |
cosh(number) Get the hyperbolic cosine of the number. Parameter: · number – The number to get the hyperbolic cosine of. |
cosh(0.0) = 1.0 |
cot |
Cotangent |
cot(number) Get the cotangent of the number. Parameter: · number – The number to get the cotangent of. |
dateDiff |
Date Difference |
dateDiff(startDatetime,endDatetime,unit) Calculates the difference in whole units between two time values, the return value is positive if endDatetime comes after startDatetime, and is negative if endDatetime comes before startDatetime. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, AND ‘NANOSECONDS’. Parameters: · startDatetime – The first (later) Date/Time value. · endDatetime – The second (earlier) Date/Time value. · unit – The time unit to use. |
dateDiff(#2019-06-17#,#2019-06-14#,’DAYS’) = 3 |
dateDiff2 |
Date Difference |
Calculates the difference in fraction units between two time values, the return vallue is positive if endDatetime comes after startDatetime, and is negative if endDatetime comes before startDatetime. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, AND ‘NANOSECONDS’. Parameters: · startDatetime – The first (later) time value. · endDatetime – The second (earlier) time value. · unit – The time unit to use. |
dateDiff2(#2019-06-17T12:00:00#,#2019-06-14T00:00:00#,’DAYS’) = 3.5 |
datePart |
Date Part |
Returns a specified part of a time value, the result is an integer value. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, AND ‘NANOSECONDS’. Parameters: · datetime – The Date/Time value. · part – The time part to get. |
datePart(#1973-07-23#,’YEARS’) = 1973 |
dateTrunc |
Date Truncate |
dateTrunc(datetime,datetimePart) Truncates the specified time value to the accuracy specified by the time_part. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, AND ‘NANOSECONDS’. Parameters: · datetime – The Date/Time value. · datetimepart – The Date/Time part to be truncated. |
dateTrunc(#1973-07-23T12:34:56#,’YEARS’) = #1973-01-01T00:00:00# |
exp |
Exponential |
exp(number) Find the value of e raised to the power of a number. Parameter: · number – The power that e is raised to. |
exp(0.0) = 1.0 |
find |
Find |
find(findText,withinText,startPosition) Returns the starting position of one string within another string, given a starting position. Parameters: · findText – The text to find. · withinText – The text to search witihin. · startPosition – Start the search from this position (optional). |
find(‘ab’,’drabant’) = 3 |
floor |
Floor |
floor(number) Returns the largest real value that is less than or equal to the argument and is equal to a mathematical integer. Parameter: · number – The number to get the flloor value of. |
floor(4.7) = 4.0 |
get |
Get |
get(array,position) Gets the nth element of the array. Parameters: · array – Array of items. · position – Array element at this position. NOTE: Index of the array starts with 0. |
get(array(5,1.1),1) = 1.1 |
a |
if |
If |
if(condition,exprIfTrue,expIfFalse) The function provides branching capability. If condition is true, then it returns exprIfTrue, else it returns exprIfFalse. Parameters: · condition – A value or logical expression that can be evaluated as true or false. · exprIfTrue – The value to return when condition evaluates to true. · exprIfFalse – The value to return when condition evaluates to false. |
if(a < b, a,b) |
a |
ifNull |
ifNull |
ifNull(expression,altValue) The ifNull function returns the specified value if the expression is null, otherwise returns the expression. Parameters: · expression – The expression to test whether it is null. · altValue – The value to return if the expression is null. |
ifNull(null, ‘b’) = ‘b’ |
a |
index |
Index |
index(array,text) Sorts the input array and outputs a lookup index. Parameters: · array – Array of items. · text – The order which the array should be sorted, the valid texts are ‘asc’ for ascending order or ‘desc’ for descending order. |
index(array(3,#1973-07-23#),’asc’) |
intpow |
Integral Power |
intpow(number,power) Raise a number to a power. Parameters: · number – Number to raise a power. · power - The power to raise a number to. |
intpow(2.0, 3.9) = 8.0 |
invert |
Invert |
Inverts a lookup index. Since the index function returns an inverse permutation, you can apply the invert function which will turn it into a forward permutation (or rank). |
left |
Left |
left(text,numofChars) Returns the leftmost characters from a string producing a new string. Parameters: · text – The text from which to extract characters. · numofChars – Number of characters to be picked from the left. |
left(‘olle’, 3) = ‘oll’ |
len |
Length |
len(value) Returns the number of characters in a string or the number of elements in an array. Parameter: · value – String or array to find the length of. |
len(‘olle’) = 4 |
ln |
Logarithm |
ln(number) The natural logarithm (base e) of a real value. Parameter: · number – A number to take the natural logarithm of. |
ln(1) = 0 |
log |
Logarithm |
log(number) Logarithm with base 10. Parameter: · number – Number of which you want the logarithm. |
log(1000.0) = 3.0 |
logn |
Logarithm |
logn(number,logBase) Returns the Log Based N of Input. Parameters: · number – Number of which you want the logarithm. · logBase – Base of the logarithm. |
logn(4711.0,4711.0) = 1.0 |
lower |
Lower |
lower(text) Convert text to lower case. Parameter: · text – Text to change case to lower. |
lower(‘OLLE’) = ‘olle’ |
a |
max |
Maximum |
Maximum of the two numbers. |
max(11.0, 47.0) = 47.0 |
mid |
Mid |
mid(string,startPosition,numofChars) Returns the characters from the middle of a text string, given a starting position and length. Parameters: · string – The original string. · startPosition – Starting position in string. · numofChars – Length of the substring. |
mid(‘olle’, 2,2) = ‘ll’ |
min |
Minimum |
Minimum of the two numbers. |
min(47.0, 11.0) = 11.0 |
pow |
Power |
pow(number,power) Raise a number to a power. Parameters: · number – Number to raise a power. · power – The power to raise a number to. |
pow(-2.0, 7.0) = -128.0 |
proper |
Proper |
proper(text) Converts a text to proper case; the first letter in each word in uppercase, and all other letters in the lower case. Parameter: · text – The text to make as a proper case. |
proper(‘olle asp’) = ‘Olle Asp’ |
a |
random |
Random |
random(minimumValue,maximumValue) Returns a random number with a positive sign. Parameters: · minimumValue – Minimum value or a random number (optional). · maximumValue - Maximum value or a random number (optional). |
random(12.0) get a floating-point random number greater than or equal to 0.0 and less than 12.0 |
replaceAll |
Replace All |
replaceAll(string,oldText,newText) Replaces all occurences of the pattern with the replacement string. Parameters: · string – The original string. · oldText – The string to be replaced. · newText – The new replacement string. |
replaceAll(‘axa’, ‘a’, ‘b’) = ‘bxb’ |
a |
replaceFirst |
Replace First |
replaceFirst(string,oldText,newText) Replaces the first occurrence of the pattern with the replacement string. Parameters: · string – The original string. · oldText – The string to be replaced. · newText – The new replacement string. |
replaceFirst(‘axa’, ‘a’, ‘b’) = ‘bxa’ |
a |
right |
Right |
right(text,numofChars) Returns the rightmost characters from a string producing a new string. Parameters: · text – The text from which to extract characters. · numofChars – Number of characters to be picked from the right. |
right(‘olle’, 3) = ‘lle’ |
rnd |
Rnd |
rnd(scaleValue) Returns a random number with a positive or negative sign depending on scale value. Parameter: · scaleValue – Positive scaleValue will result in a number that is maximum up to it and the negative scaleValue will result in a number that is minimum to it. |
round |
Round |
round(number,digits) Round a number to a given number of digits. Parameters: · number – The number to round. · digits – The place at which number should be rounded (optional). |
round(47.11) = 47.0 |
set |
Set |
set(array,position,newvalue) Sets the nth element of the array. Parameters: · array – Array of items. · position – Array element at this position. · newvalue – New value of the element. NOTE: Index of first element starts with 0. |
set(array(5, 1.1), 1, 2.2) |
a |
sign |
Sign |
sign(number) Get the sign of a number, returns one if positive, negative one if negative, and zero if zero. Parameter: · number – The number to get the sign of. |
sign(7) = 1 |
sin |
Sine |
sin(number) Get the sine of the number. Parameter: · number – The number to the sine of. |
sinh |
Sinus Hyperbolic |
sinh(number) Get the sinus hyperbolic of the number. Parameter: · number – The number to the sinus hyperbolic of. |
sinh(0.0) = 0.0 |
sort |
Sort |
Applies a lookup index to an array. |
sqr |
Square |
sqr(number) Returns square of the number. Parameter: · number – The number to get the square of. |
sqr(3) = 9 |
sqrt |
Square Root |
sqrt(number) Returns square root of the number. Parameter: · number – The number to get the square root of. |
sqrt(9.0) = 3.0 |
tan |
Tangent |
tan(number) Get the tangent of the number. Parameter: · number – The number to get the tangent of. |
tan(0.0) = 0.0 |
trim |
Trim |
trim(text) Get the input text stripped of leading or following spaces. Parameter: · text – The text to be stripped of leading or following spaces. |
trim(‘ olle ’) = ‘olle’ |
a |
trunc |
Truncate |
trunc(number,digits) Truncate a number to a given precision. Parameters: · number – The number to truncate. · digits – The precision of the truncation (optional and the default is 0). |
trunc(47.11) = 47.0 |
upper |
Upper |
upper(text) Convert text to upper case. Parameter: · text – Text to change case to upper. |
upper(‘olle’) = ‘OLLE’ |
