Saving an Application
Saved applications (.app) are available in the PanopticonAppdata\CEP\Applications folder (i.e., c:\streamsserverdata\CEP\Applications).
1. In the Application page, you can either click:
· the Save
icon
· the
icon.
The context menu displays with three saving options:
Save
Click to save the changes made in the application.
Save
as Copy
Click to make a duplicate of the application. The original name is appended with _Copy.
To
change the Application Name, click on it to make it editable,
then enter a new one and click
NOTE |
The Name or ID must start with a letter (a to Z) or underscore. Also, it can only contain letters (a to Z), numbers (0 to 9), and underscores.
Revert
to Saved
Click to revert to the previously-saved application settings.
NOTE |
· After saving, you can start the execution of the application. You can do this either in the Application page or on the Applications tab. · When saving an application, the color will indicate the status of the nodes: o o o
Black
– no issue
Yellow
– no traffic on the topic
Red
– there are definition issues. Refer to
