Moving Data Sources
Users with a Designer role can move data sources to folders or subfolders to which they have permission.
1. Check the box of multiple data sources either on the Grid View or List View.
2. Then select either:
· the Move icon
on the toolbar
· Move on the context menu
The Move Data Source dialog displays with the folder or subfolders to which the user has permission to move the data sources.
3. Select the folder or subfolder.
4. Click .
The data sources are moved and displayed on the selected folder.
NOTE |
If data sources with the same name are already in the selected folder, a copy of them will be moved. |
