Moving Data Sources Using the Context Menu
Users with a Designer role can move several data sources to other folders or subfolders.
1. Check the box of multiple data sources either:
· on the Grid View, or
· on the List View
2. Right-click on a data source and select Move on the context menu.
On the Grid view:
On the List view:
The Move Data Source dialog displays with the folder or subfolders to which the user has permission to move the data sources.
4. Select the folder or subfolder.
5. Click .
The data sources are moved and displayed on the selected folder.
