Copying Data Sources
Users with a Designer role can copy data sources to folders or subfolders to which they have permission.
1. Check the box of one or multiple data sources either on the Grid View or List View.
2. Then select either:
· the Copy
icon
on the toolbar
· Copy on the context menu
The Copy Data Source dialog displays with the folder or subfolders to which the user has permission to copy the data sources.
3. Select the folder or subfolder.
4. Click
The data sources are copied and displayed on the selected folder.
NOTE |
If data sources with the same name are already in the selected folder, it will be added as copy.
