Deleting Data Sources Using the Context Menu
1. You can either:
· right-click on a data source and select Remove
· check several boxes of data sources then right-click and select Remove
A confirmation message displays.
For a data source, the corresponding applications that will be impacted is listed:
For several data sources:
2. Click to delete.
