Example 2: Export data sources from all workbooks example
java -jar pcli.jar exportdatasource
-wd "C:/vizserverdata/Workbooks"
-l "C:/vizserverdata/DatawatchLicense.xml"
-dd "C:/vizserverdata/Data"
-od "C:/streamsserverdata/CEP/Datasources"
Where:
q C:\vizserverdata is the AppData folder of the Visualization server
q C:\streamsserverdata is the AppData folder of the Streams server
