[6] Managing the Streams System
The System tab displays the following sections where an administrator can:
q view the active license
q monitor and set the File Logging Level
q select the Metrics Publisher
q view the server properties
q view Kafka properties
If the licensing used is the Altair Units license, the page will be displayed as:
If the licensing used is the volume-based XML file (named PanopticonLicense.xml), the page will be displayed as:
