Defining Real-time Settings
Streaming connectors have a common section to specify the Time Id Column to generate the streaming time series window. The Time Id Column can be from the soure dataset, or alternatively, automatically generated.
As new data arrives from the subscription, new time slices will automatically be added, and old ones will be deleted.
1. Select either:
· Automatic Time Id
Then define the Time Id Column Name.
· Date/Time Id column either from the source data or automatically generated
2. Check the Reset Data on Reconnect box to flush out the stale data and reload data after reconnection.
