Defining the Message Type in Data Sources
Message types specify the format of the data within the message.
1. Select the Message Type:
· FIX
· JSON
If JSON is selected, enter the Record Path which allows the identification of multiple records within the JSON document (e.g., myroot.items.item).
· Text
If Text has been selected, confirm the Decimal Separator, Text Qualifier, Column Delimiter, and if the first row of the message includes column headings.
· XML
2. Define or set the columns that represent the sections of the message.
Property |
Description |
Name |
The column name of the source schema. |
Fix Tag/JsonPath/Text Column Index/XPath |
The Fix Tag/JsonPath/Text Column Index/XPath of the source schema. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message field should be processed. |
NOTE |
To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them. For example: yyyy-MM-dd HH:mm:ss.SSSSSS
To
delete a column, check its
or all the column
entries, check the topmost
, then click .
