Add Point Vents
Add point vents to enable gases to escape from around the part and through the exterior of the mold.
The table shows the current coordinates and radius or dimensions for each vent. Use the dropdown menu to select squared vents or circular vents.
Column 1 numbers the vents in the order that you added them. The Location column pinpoints the vent at X, Y, and Z coordinates. For round vents, the Radius column displays the vents' radii. For squared vents, the X, Y, and Z columns display the vents' dimensions. When a row is selected, you can use the microdialog to edit the corresponding vent.
Click the icon to export vents to a .csv or .txt
file.
Click the icon to import vents from a .csv or .txt
file.
