2022
Discover SimSolid functionality with interactive tutorials.
Learn about using other products with SimSolid.
View new features for SimSolid 2022.
Links to SimSolid instructional videos.
Learn how to access and download required model files.
Learn how to export data from Altair EDEM for use in linear structural analysis in SimSolid.
Learn about Assembly in SimSolid.
Learn about Connections in SimSolid.
Learn about Boundary Conditions in SimSolid.
Learn about Analysis in SimSolid.
Learn about Post Processing in SimSolid.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
