SS-T: 4030 Thermal Analysis, Cup
Perform a thermal analysis on a cup model.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Learn how SimSolid works.
- Setup a thermal analysis in SimSolid.
- Model Description
- The following model file is needed for this tutorial:
- cup.ssg
Import Geometry
Assign Materials
Create Thermal Analysis
Apply Temperature
Apply Convection
- In the Project Tree, click on a Thermal analysis branch to open the Analysis Workbench.
On the workbench toolbar, click the
(Convection) icon.
- In the dialog, verify the Face radio button is selected.
Select the outer faces of the cup.
- For Ambient temperature, enter 22.
- For Convective heat transfer coefficient, 5.48e6.
- Click OK.
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings: custom.
- In the Solution settings dialog, for Objective select Adapt for stiffness in the drop-down menu.
- Click OK.
Run Analysis
- In the Project Tree, open the Analysis Workbench.
Click
(Solve).
