SS-T: 3010 Imported Forces and Remote Loads
Use imported forces and remote loads in SimSolid analyses.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Learn how to import forces and remote loads from .csv files into SimSolid.
- Model Description
- The following model files are needed for this tutorial:
- Import_Forces_RemoteLoads.ssp
- Import_RemoteLoads.csv
- ImportLoads.csv
Open Project
Import Forces
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings: custom.
- In the Solution settings dialog, for Objective select Adapt for stiffness in the drop-down menu.
- Click OK.
Run Analysis
- In the Project Tree, open the Analysis Workbench.
Click
(Solve).
Plot Displacement Contour
Create Second Structural Linear Analysis
Import Remote Load
- Click OK.
Run Analysis
Click
(Solve).
View a contour plot for displacement magnitude.
