Troubleshooting: Can't Select Reference Geometry
Condition
There are two possible scenarios:
Cause 1
You tried to select a solid or non-planar surface. You can only select planar surfaces as reference geometry.
Remedy 1
Cause 2
Draft Analysis is turned on.
