Create Drawbead
Create a drawbead from a bead line.
- On the ribbon, click the Die Design tab.
Click the Drawbead icon.
Select the Drawbead tool on the secondary ribbon.
- Select the die.
- Select the bead line(s).
- In the guide bar, select the bead shape, and then right-click to create the drawbead.
Edit the drawbead.
To Do This Add a profile Press Alt and click anywhere on the bead line. Edit a bead profile - Click a handle, enter a Radius, then press Enter.
- Click a handle, enter a Length, then press Enter.
Edit bead entry radius - Click the fillet blue triangle.
- Enter a Radius, then press Enter.
Edit an endbead angle Click the blue point on the end of the bead. - Click the white arrow, enter an Endbead Angle, then press Enter.
- Drag the white arrow.
Note: The endbead angle has a minimum and maximum angle of 20 and 60 degrees.Clear selection In the guide bar, click .
