Define the symmetry boundary conditions. You can define up to two symmetry planes. The second symmetry plane must
be parallel or orthogonal to the first.
Create one or more surfaces that extend from the part to the binder, to aid in stretching and forming. These tools
allow for more control over surfaces.
Export selected objects to a common folder used to exchange data with other Altair products. For example, you can export a die design from Inspire Studio to Inspire Form to perform a stamping simulation.
First define the part and then adjust the draw direction to create a draw
die.
Assign
Select a part and define the thickness and position.
Symmetry
Define the symmetry boundary conditions. You can define up to two symmetry planes. The second symmetry plane must be parallel or orthogonal to the first.
Set Draw Direction
Adjust the draw direction to minimize the depth and avoid negative drafts with the help of the Depth Box and Draft Analysis.
Extend (Part)
Create one or more surfaces that extends the part to create a die, to aid in stretching and forming.
