Trim Extend
Trim the addendum extend surface with the wall.
- On the ribbon, click the Die Design tab.
Click the Addendum Extend icon.
Select the Trim Extend tool on the secondary
ribbon.
- Select the binder, and right-click to confirm.
The wall is selected automatically. Right-click to confirm.
Note: If there are multiple walls, left click to add or remove.
The extend surface is selected automatically.
Note: If there are multiple extend surfaces, left click to add or remove. The extend bridge surface is not automatically selected, it must be selected manually.
In the guide bar, select a trim option, and then right-click to confirm.
- Trim and Fillet
- Trim
- In the modeling window, hover and click highlighted trim surfaces to select or remove.
- Optional:
If Trim and Fillet was selected, adjust fillet:
Method Description To define the same radius for all fillets Click a fillet and enter a Radius. To define variable fillets Press Alt and click a blue dot to add a fillet location. Enter a Radius. - Right-click and mouse through the check mark to exit, or double-right-click.
