This tool has two modes: Push/Pull allows you to move faces, changing the size or shape of your design. Move Feature allows you to translate and rotate a feature (a set of faces such as a hole, pocket, or protrusion). This
tool only works on objects without construction history.
Note: This tool only works on objects without construction history. To collapse the
construction history of a selected object, press
Alt+C.
On the ribbon, click the Direct tab.
Click the Push/Pull icon.
Do one of the following:
To
Do this
Push/pull faces
In the guide bar, select Operation:
Push/Pull.
Select a face.
Drag the arrow.
Click the arrow and enter a
Distance.
In some cases, such as a round, push/pulling a
face moves the adjacent faces too. To move a
single face in a group such as a round, in the
guide bar select Step
, and then drag the
arrow.
Repeat the steps above to push/pull additional faces
on the same or a different object.
Translate and rotate a feature
A feature is a set of faces such as a hole, pocket, or
protrusion.
In the guide bar, select Operation: Move
Feature.
Select a face of the feature that is along the
boundary edge.
Note: The feature can
intersect only one face of the object.
The Move tool opens automatically. Use the
Move tool to rotate and
translate the feature.
Right-click and mouse through the check mark to exit, or double-right-click.
