Disk
Create and edit a disk.
Create a Disk
Create a disk, with or without a hole in the center.
- On the ribbon, click the Surfaces tab.
Click the Disk icon.
- Drag to define the outer diameter.
- Move the cursor to define the inner diameter, and then click.
Edit a Disk
Resize the disk or change the sweep angle.
