Create and edit 3D surfaces and solids by creating primitives or editing existing curves and surfaces.
Create the basic shape of a 3D surface.
Discover new features and enhancements.
New to Inspire Studio? Learn the basics here.
Start using Inspire Studio with our interactive tutorials.
Create and edit a 2D sketch curve. A sketch curve is any "wire" entity such as a line, rectangle, circle, or arc.
Create and edit 3D curves by extending, rebuilding, intersecting, splitting, and projecting the shapes.
Create and edit a plane or a square.
Create and edit a cube or a rectangular solid.
Create and edit a sphere.
Create and edit a cylinder or a cone.
Create and edit a disk.
Create and edit a torus.
Create a 3D text object. You can fill or extrude the text and change the font and size.
Perform an operation on existing curves or surfaces to create a new 3D surface or solid.
Directly edit the geometry of a NURBS surface by performing various operations such as moving, adding, and removing points; changing the order in the U or V direction; adding weight; and removing trimming curves.
Create polygonal surfaces that can easily be converted into NURBS surfaces.
Create new objects by manipulating and modifying source objects.
Quickly modify objects that are not a part of Construction History.
Deform one or more objects with respect to an axis.
Analyze curves and surfaces, import simulation data, or access the Design Table and Variable Manager.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined dimensions.
Create detailed 2D drawings of the selected parts of a complex 3D model from multiple perspectives.
Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
In Inspire Studio you can animate an object or group and the camera. There are two methods of animation: key frame animation and path animation.
Create a draw die in Inspire Studio that you can export to Inspire Form to perform a stamping simulation.
You can use C++ and Python to add custom operations and file formats.
Learn keyboard shortcuts and mouse controls for common operations.
Inspire Studio supports 3Dconnexion's SpaceMouse.
