Sweep one or more curves along rails to create a 3D surface. This tool is a variation of the Sweep tool that uses
two rails rather than one extrusion path.
Fill a closed area, defined by boundary curves or surface edges, to create a 3D surface. The new surface maintains
tangent continuity with adjacent surfaces.
Directly edit the geometry of a NURBS surface by performing various operations such as moving, adding, and removing
points; changing the order in the U or V direction; adding weight; and removing trimming curves.
Perform an operation on existing curves or surfaces to create a new 3D surface or
solid.
Extrude
Extrude a curve to create a 3D surface, or extrude a surface to create a solid. You can perform the same extrusion on multiple objects at a time.
Revolve
Rotate a curve or 2D surface around an axis to create a 3D surface. You perform the same revolve on multiple objects at a time.
FillPath
Fill one or more closed curves to create a 3D surface. The curves can be sketch curves or a planar set of curves.
Loft
Create a 3D surface by fitting it through two or more profile curves. You can constrain the shape using rails.
Sweep
Sweep one or more curves along an extrusion path to create a 3D surface.
Rail Sweep
Sweep one or more curves along rails to create a 3D surface. This tool is a variation of the Sweep tool that uses two rails rather than one extrusion path.
Patch
Fill a closed area, defined by boundary curves or surface edges, to create a 3D surface. The new surface maintains tangent continuity with adjacent surfaces.
