Save or Export a FileSave a File
Save a scene, a bundle, selected objects, a selected model, or a Studio set. You can change the autosave settings and turn on Safe save.
By default, models created in Inspire Studio are saved in the native format with the file extension .istudio.
By default, models created in Inspire Render are saved in the native format with the file extension .irender.
When you save a file, you save not only its geometry, but also materials and display information, which includes views mode, zoom level, snaps, and grids status.
To | Do this |
Save the scene |
Save as |
Save an .iStudioPack (Save textures, labels, and background images with your model) |
Save selected objects |
Save a selected model to the Model Library |
Save the Studio set (Save only the lights and rendering environment of the scene) |
Change the autosave settings |
Turn on Safe save |
