Tool Belts
Inspire Studio has four different tool belts to help you quickly access the tools you need for 3D modeling, sketching, creating PolyNURBS, and rendering. You can use the tool belts with the default configuration of tools or you can customize the tool belts by adding and removing tools as required.
Main Tool Belt for 3D Modeling
The default configuration for this tool belt includes tools for 3D modeling from the Curves, Surfaces, Deform, and Modify ribbons. To open this tool belt, hold down Alt and right-click on empty space.
Sketching Tool Belt
The default configuration for this tool belt includes tools from the Sketching ribbon. To open this tool belt, hold down Shift+Alt and right-click on empty space.
PolyNURBS Tool Belt
The default configuration for this tool belt includes tools from the PolyNURBS ribbon. To open this tool belt, hold down Ctrl + Alt and right-click on empty space.
Rendering Tool Belt
Customize the Tool Belts
Customize the tool belts to quickly access your favorite tools.
