In Inspire Studio, the default unit of measurement is
centimeters. You can also choose from millimeters, meters, inches, and feet.
When you enter a number in a field, the appropriate unit is automatically appended. If you
enter a unit after a number, the number is converted to the current unit. For example,
entering 10 in inside a field where centimeters are the current
units results in 25.4 cm being displayed.Tip: When
unit conversion is required, include the units when entering the value. Use standard
unit abbreviations without a space. For example, to enter a value of 1 inch, type
1 in.
On the Help menu, click the
Preferences button.
In the Preferences window, click Inspire Studio >
Units.
You have the following options:
Preference |
Description |
Length |
Define the units used for length. |
Mass |
Define the units used for mass. |
Area |
Define the units used for area. |
Volume |
Define the units used for volume. |
Density |
Define the units used for density. |
Moment of Inertia |
Define the units used for moment of inertia. |
Curvature |
Define the units used for curvature. |
Save as Defaults |
Click the Save as Defaults button to
save the values entered in the tolerance fields as your standard
default settings. |
Note: The grid settings update automatically. For example, if Grid #2 spacing has been
set to 1 cm, when you switch from centimeters to inches, Grid #2 spacing will
automatically update to 1 in.
