Geometric Design
Plane | X (mm) | Y (mm) | Z (mm) | Width (mm) | Depth (mm) |
1 | -250 | -250 | 0 | 500 | 500 |
2 | -250 | -250 | thickness | 500 | 500 |
3 | -250 | -250 | thickness+t | 500 | 500 |
4 | -250 | -250 | (2*thickness)+t | 500 | 500 |
Figure 1. Command line planes definition
Figure 2. List of geometric entities in the tree
After creating the four planes, in the tree we can see that they have been added in order as Objects, and each one has a different name.
