Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Use a custom mesh to accurately resolve the geometry.
  1. Set the Mesh size equal to Custom.
  2. Set the Triangle edge length equal to 4 cm.
  3. Set the Wire segment length equal to cap_length.
  4. Set the Wire segment radius equal to 0.01 cm.
