Using a Lua Script to Configure Graphs
View the Lua script to set up the graphs for the input reflection coefficient and circular components of the far field.
The step-by-step instructions to create this script is beyond the scope of the Feko Getting Started Guide, but it is recommended to view the script and to compare it with setting up Graph 1 and Graph 2 from Example 3.
app = pf.GetApplication() -- Graph 1 graph1 = app.CartesianGraphs:Add() excitationTrace = graph1.Traces:Add(app.Models[1].Configurations[1].Excitations[1]) excitationTrace.Quantity.ValuesScaledToDB = true graph2.Footer.Text = "" graph2.Legend.Position = pf.Enums.GraphLegendPositionEnum.OverlayBottomRight -- Graph 2 graph2 = app.CartesianGraphs:Add() farFieldTraceLHC = graph2.Traces:Add(app.Models[1].Configurations[1].FarFields[1]) farFieldTraceLHC.Quantity.Type = pf.Enums.FarFieldQuantityTypeEnum.Gain farFieldTraceLHC.Quantity.Component = pf.Enums.FarFieldQuantityComponentEnum.LHC farFieldTraceLHC.Quantity.ValuesScaledToDB = true farFieldTraceRHC = farFieldTraceLHC:Duplicate() farFieldTraceRHC.Quantity.Type = pf.Enums.FarFieldQuantityTypeEnum.Gain farFieldTraceRHC.Quantity.Component = pf.Enums.FarFieldQuantityComponentEnum.RHC farFieldTraceRHC.Label = "FarField2" farFieldTraceRHC.Quantity.ValuesScaledToDB = true graph2.Footer.Text = "" graph2.Legend.Position = pf.Enums.GraphLegendPositionEnum.OverlayBottomRight
Note: For more
information regarding scripts and the Feko application
programming interface (API), see the Feko Scripting and API Reference Guide.
