The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in
CADFEKO.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated
automatically for all voltage and current sources in the model.
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a
hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated
and displayed.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
The example considers the transmission and reflection coefficients of a waveguide
power divider.
Example Overview
Calculate the transmission and reflection coefficients of a waveguide power divider.
Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Example Prerequisites
Before starting this example, ensure that the system satisfies the minimum requirements.
Launching the Solver
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Final Remarks
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated and displayed.
