Create a Multiport Lua Settings File
The Multiport post-processing application macro can be configured to use a Lua settings file to define the loading and excitation for each port. This simplifies the procedure for frequent calculations or large multiport setups with many ports.
- Active ports configuration
- Non-active ports configuration
- Field data configuration
- Processing options
return {activePortsConfiguration,nonActivePortsConfiguration,fieldDataConfiguration,processingOptions}
- The fieldDataConfiguration table is only required for the measurement method of the Multiport post-processing application macro to map the field data to the correct ports.
