S-parameters
S-parameters data consist of the S-parameters for all active ports as well as a table of reference impedances used at each port.
S-PARAMETER REFERENCE IMPEDANCES AT PORTS
port impedance in Ohm
1 5.00000E+01
2 1.00000E+02
DATA FOR EDGE LOADS Name: Load index: 1 Load type: Resistor Complex impedance: ( 5.00000E+01 +j 0.00000E+00) Ohm (freq. dep.) Attached to port: Edge port Port between triangle labels: Union1.Face53_1 Union1.Face53_2 Port edge length in m: 4.60000E-03 Number of edges: 2 Indices of the edges: 809 814
SCATTERING PARAMETERS
ports magnitude phase
sink source real part imag. part linear in dB in deg.
S 1 1 8.20232E-01 -3.08302E-01 8.76260E-01 -1.1473 -20.60
S 2 1 -1.09955E-02 -5.19575E-03 1.21613E-02 -38.3004 -154.71
Sum |S|^2 of these S-parameters: 7.67979E-01 -1.1465
