Specifying the Prediction Resolution and Height
Define the resolution grid and the height where the prediction results are to be calculated.
Figure 1. The Edit Project Parameters dialog - Simulation tab.
The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
This example considers the application of analyzing a Wi-Fi router in a building.
This example considers the application of analyzing the indoor cell-phone reception, set in an urban environment.
This example considers the application of analyzing base stations in a city, set in an urban environment.
This example considers the application of analyzing base stations on hills near a city, set in a rural or suburban hilly terrain.
This example considers the application of analyzing base stations in a rural or suburban hilly terrain.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Pixel databases are used to describe the topography, land usage and buildings in a rural/suburban scenario to obtain accurate predictions.
Set up the propagation simulation parameters. Solve the rural/suburban database and inspect the coverage plots for various models.
Launch ProMan in Microsoft Windows using the Feko Launcher utility (which includes WinProp and newFASANT).
View the clutter database to obtain information regarding land usage.
Define the first cellular base station located on the highest hill. The antennas are placed 30 m above ground.
Define the second cellular base station located on a lower hill. The antennas are placed 30 m above ground.
The rural/suburban database is solved using the dominant path model (DPM).
Specify the folder for the prediction results to be computed using the DPM.
Specify the predictions to be computed.
Select the dominant path model (DPM) as computation method.
Save the new project to file.
Compute the propagation for all antennas to obtain the prediction results.
Display the power results using the dominant path model (DPM).
The rural/suburban database is solved using the deterministic two ray model (DTR).
This example showed how to analyze two cellular base stations set in a rural/suburban scenario with hilly terrain and to obtain coverage plots using ProMan.
This example considers the application of analyzing three base stations, set in a building. The network planning simulation is based on a pre-defined air interface file.
The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
The WallMan component offers a convenient facility to generate and edit vector building databases.
The TuMan tool enables you to generate and modify tunnel scenarios.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
The WinProp utilities consist of the Launcher utility and the Updater.
