Selections allow data to be extracted from a particular area or element in the domain. Using selections, you can monitor any element passing through a particular area (known as a “bin”) or track particular elements wherever they move within the domain. You can then display, color, graph, or export data based on these selections and sub-selections.
Setup selections works with Display Selections once configured.
Right clicking on the Setup Selections Section (or using
) will allow you to add selections of the following types:
Right clicking on a specific selection from the Tree will allow you to:
A manual selection lets you select and track individual particles, contacts, geometries,
or bonds. You can then display, color, graph or export data based on these selections.
You can also define and add queries, as well as display detail in the data browser.
If an element is not displayed in the Viewer it will not be captured by the selection box. All selected elements are highlighted in orange by default. Additional selection boxes can be drawn to add further elements to the selection.
All captured elements are listed by their ID in the Manual Selection area. Click the x button to remove them completely from the selection.
If you know the specific ID it is possible to paste this into the geometry of particle sections of the manual selection box.
Select the Display in Data Browser checkbox to add information on elements in the selection to the Selection section within the Data browser.
This example shows a selection group where several particles have been individually selected. Coloring has been applied to show Velocity:
Example where material has been selected in bands, each band colored differently to show the cut-depth of the material:
A Grid Bin Group splits the model domain into a lattice. Each grid is known as a bin group and each cell is known as a bin. Anything in or moving through each bin can be monitored.
To create a Grid Bin Group, from the Setup Selections Section right click and select “Add Selection” then choose Grid Bin Group. Define the selection then click the Apply button to apply settings and display the group in the Viewer.
A Grid Bin Group with a highlighted bin at the center:
By default the bin group covers the entire domain; however, it can be limited to a specific area using the start and end point options:
The number of bins in the group is determined by the number of bins along each axis.
Empty bins (those containing no elements) can also be removed using the Display Mode drop-down box:
A geometry bin is a bin element based on a Box or Cylinder geometry type. You can link its position to any static or dynamic geometry section. The bin is displayed as a mesh of blue lines.
To define a geometry bin:
From the Analyst Tree, right click on the Setup Selections Section and click on “Add Selection”.
Then choose Geometry Bin.
Select the geometry type: either Box or Cylinder.
Set the bin’s properties to define its size, shape, and initial position. For cylinders, set the number of sides to determine how many polygons are used to render the bin. Fewer polygons are faster to process, but at the expense of accuracy.
Set the filter options to determine what to include in the bin. By default all particles are included.
Select the display mode and on-screen query options. For example, set the display mode so that the bin is displayed only when it contains particles.
Select whether to link the bin’s position to a geometry element defined in the Creator. This links to the center (or zero-point) of the geometry. If the geometry has dynamics, the bin will move along with it.
This example shows a geometry bin based on a cylinder. The bin indicates the mass flow rate and moves with the geometry section it’s linked to:
With the imported geometry bin group you can define a bin group based on an imported mesh file or CAD template created in another package. You can then link the bin group’s position to any defined geometry.
To define an imported geometry bin group:
Then choose Imported Geometry Bin Group.
In the CAD Template Selection section, click the Import button then navigate to a CAD template file. When prompted, set the units then tick the Merge Sections option to set the template as one bin, or leave it un-ticked to create one bin for each geometry element. The imported file must contain only solid geometry elements: you cannot import surfaces (non-closed elements such as a plane).
Select whether to link the bin’s position to a geometry element defined in the Creator. If the geometry is dynamic, the bin will move along with it.
This example shows an imported geometry bin linked to a moving bucket geometry. A query has been added to display the average particle angular velocity:
Mass flow rate is the rate at which particles pass through a bin group. It is measured in mass over time, for example, tons per hour or kilograms per second. Mass flow analysis enables the calculation of the rate of mass flow in a certain volume within the simulation. The user creates the volume (a cylinder) and places it within the model domain.
The calculation for mass flow rate for a single time step is
Where:
= Magnitude of the mass flow rate.
= The mass of particle i the selection bin.
= The velocity of particle i in the selection bin as a vector.
= The length of the cylinder as a unit vector.
For each particle its mass is multiplied by the dot product of its velocity and the unit vector of the cylinder from start to end. Each of these per particle values are then summed and divided by the length of the bin. The length of the bin is the distance from the start point to the end point of the cylinder.
To define the mass flow:
Then choose Mass Flow Sensor.
Set the mass flow sensor’s properties to define its size, shape, and initial position. For cylinders, set the number of sides to determine how many polygons are used to approximate the circumference of the cylinder. Fewer polygons are faster to process, but at the expense of accuracy.
Set the filter options to determine what to include in the calculation of the mass in the bin. By default all particles are included.
Velocity Profile Sensors can be added to the model to obtain the average velocity of the bulk material within user-specified regions of a simulation.
To analyze the velocity profile of bulk material:
From the Analyst, right click Setup Selections, hover over Add Sensor Selection and select Velocity Profile Sensor.
Toggling the Retain selections over time checkbox allows the particles that pass through the sensor to be kept as part of the selection group.
The Display in Data Browser checkbox toggles the display of the value of the sensor result in the Data Browser window.
The Component list allows the user to select the component of velocity they are interested in. Choose from Magnitude, X, Y or Z.
The lists in the Type Filter section allow the user to select which particles, Geometries, bonds and types of contact they wish to include / exclude.
The representation options allow the user to toggle whether the query is displayed on screen.
You can choose between two different primitive shapes for the sensor: box or cylinder.
Set the sensor’s dimensions and position.
The sensor’s position can be linked to a geometry, which can be useful when analyzing moving Geometries.
Total Mass Sensors can be added to the model to measure the total amount of bulk material contained within a region at any one point in time, or cumulatively over a period of time.
To analyze the total mass of material:
From the Analyst, right click Setup Selections, hover over Add Sensor Selection and select Total Mass Sensor.
Toggling the Cumulative Total Mass keeps track of the Total Mass that has passed through the sensor for all analyzed time steps.
Segregation Sensors can be added to the model to measure the average size of the elements that make up the bulk material contained within a sensor.
Segregation is calculated using:
Volume:
Mass:
To analyze the segregation of the bulk material:
From the Analyst, right click Setup Selections, hover over Add Sensor Selection and select Segregation Sensor.
The Segregation Attribute list allows the user to select whether they would like to analyze the segregation by Mass or Volume.
Bulk Density Sensors can be added to the model to measure the average density of the elements that make up the bulk material contained within a sensor.
To analyze the density of the bulk material:
From the Analyst, right click Setup Selections, hover over Add Sensor Selection and select Bulk Density Sensor.
The Density Type list allows the user to select whether they would like to analyze the Bulk Density or Solids Density.
A query is used to define a single element attribute, for example, particle velocity, total force on a geometry section or number of collisions. The query information can then be displayed in the Viewer and in the Groups section in the Data Browser. Bin cells can also be colored according to the results of the query.
To define a query, click the Edit button in the Options section. The Selection Query Editor is displayed:
When using Manual Selection the particles or geometries selected remain selected over time. If using the other selection options (Grid Bin Group, Geometry Bin etc.) the particles or geometries are only selected by default if the center of the particle or geometry is inside the bin group. Once they move outside the bin they are automatically removed from the selection.
If the “Retain Selections Over Time” option is checked any particles passing through the selection group will selected and remain selected once they have exited the selection group. In the image below a geometry bin has been created, as the particles pass through the bin they are highlighted orange and remain colored once they have left the bin area.
Affects all contacts or any combinations of specific particle-particle or particle-geometry contacts.
| Attribute | Query Type | Component |
Contact vector 1. |
Average, maximum, minimum or total. |
Magnitude, X, Y, Z. |
Contact vector 2. |
Normal force. |
Normal overlap. |
N/A |
Number of contacts. |
N/A |
N/A |
Tangential force. |
Tangential overlap. |
N/A |
Custom property. |
Depends on number of elements. |
| Contract Normal (Polyhedral) | Average, maximum, minimum or total. | X, Y, Z. |
| Penetration Depth (Polyhedral) | Average, maximum, minimum or total. | N/A |
| Overlap Volume (Polyhedral) | Average, maximum, minimum or total. | N/A |
Affects all bonds or any combinations of specific particle-particle bonds.
Normal force. |
Normal moment. |
No. of broken bonds. |
N/A |
N/A |
No. of intact bonds. |
N/A |
N/A |
Tangential force. |
Tangential moment. |
Affects all geometry or a particular section (as specified in the Creator).
Compressive force. |
N/A |
Number of geometry elements. |
N/A |
N/A |
Pressure |
Maximum, minimum or total pressure. |
N/A |
Total force |
Torque (element) |
Average, maximum, minimum or total. Total is the sum of the individual element torque values. |
Velocity |
Custom property. |
Affects all particles or a particular particle type (as specified in the Creator). To cumulatively sum the number of particles over a period of time, select the 'Total over time' option. As you step forward through the simulation the total number of particles will be recorded. Cumulative particle totals for bin groups only works when stepping forward through your simulation: if you jump back, the totals may not be accurate.
Angular velocity. |
N/A |
Coordination number. |
N/A |
Diameter |
N/A |
Moment of inertia. |
Kinetic energy. |
N/A |
Mass |
N/A |
Number of particles. |
Total-over-time checkbox. |
N/A |
Potential energy. |
N/A |
Residence time. |
N/A |
Rotational kinetic energy. |
N/A |
Torque |
Total energy. |
N/A |
N/A |
Total force. |
Velocity |
Voidage [1] |
Total |
N/A |
Volume |
N/A |
Custom property. |
The Type Filter section is used to determine which elements in your model are included. By default all particles (but nothing else) are included in the group, if No Geometry or No Contacts are chosen then no data will be exported for the selected query type.
For any element, click the pull-down menu to select all, none, or selected elements:
Element |
Filter Options |
Particles. |
All Particles, No Particles, Selected Particles. |
Geometry. |
All Geometry, No Geometry, Selected Geometry. |
Surface - Geometry Contacts. |
All Surface-Geometry Contacts, No Surface-Geometry Contacts, Selected Surface-Geometry Contacts. |
Surface - Surface Contacts. |
All Surface-Surface Contacts, No Surface-Surface Contacts, Selected Surface-Surface Contacts. |
Surface - Geometry Bonds. |
Surface - Surface Bonds. |
All Surface-Surface Bonds, No Surface-Surface Bonds, Selected Surface-Surface Bonds. |
For selected elements, tick the checkbox for all elements to include.
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
