The Creator is used to setup and initialize your model. It is where you or import particles and geometries and define the other model parameters.
Creator Tree
Viewer
Creator Toolbar and Menu Bar
Data Browser (Creator)
The Creator Tree is displayed on the left side of the EDEM window. It contains information about the Project, Bulk Material, Equipment Material, Geometries, Physics and Environment.
The Viewer displays 3D representations of your particles, geometry, and fields (if applicable). The rotation, position and zoom factor of the Viewer are controlled using the mouse.
| Icon | Name | Description |
 | Creator | Click to switch to the Creator. |
 | Simulator | Click to switch to the Simulator. |
 | Analyst | Click to switch to the Analyst. |
 | New | Click to start a new model. |
 | Open | Click to open an existing model. |
 | Save | Click to save your model. |
 | Help | Click to view the online help. |
 | Change Time Step Back | Move to the first time step in the simulation. |
 | Change Time Step Forward | Move to the last time step in the simulation. |
 | Start Coupling Server | Click to start the Coupling Server. |
 | Coupling Server Disabled | Shows the Server is not running. |
 | Server Awaiting Connection | Shows the Server is started but not connected. |
 | Server Connected | Shows the Server is connected. |
 | Stop Server | Click to stop the Coupling Server. |
 | Filled Display Mode | Click to display geometry filled. |
 | Mesh Display Mode | Click to display geometry |
 | Points Display Mode | Click to display geometry |
 | Display Particles | Click to display or hide all particles. |
 | Display Cylindrical Periodic Boundary Conditions | Click to visualize cylindrical periodic boundary. |
 | Add Bulk Material | Click to add a Bulk Material to the simulation. |
 | Add Equipment Material | Click to add an Equipment material. |
 | Save Material Block | Click to save block of material for material bed. |
 | Transfer Material from Database Materials | Click to transfer materials to and from the Material Database. simulation materials with material database. |
 | Rename Material | Click to rename the selected material. |
 | Copy Material | Click to copy the selected material. |
 | Delete Material | Click to delete the selected material. |
 | Open GEMM Wizard | Click to open the GEMM Wizard. |
 | Add Particle | Click to add a particle to a Bulk Material. |
 | Import Particle | Click to import a particle to a Bulk Material. |
 | Export Particle | Click to export a particle. |
 | Rename Particle | Click to rename a particle. |
 | Copy Particle | Click to copy a particle. |
 | Delete Particle | Click to delete a particle. |
 | Add Sphere | Click to add a Sphere to a particle. |
 | Copy Sphere | Click to copy a particle Sphere. |
 | Delete Sphere | Click to delete a particle Sphere. |
 | Add a Geometry | Click to access geometry add drop down list. |
 | Add a Box | Click to add box from geometry drop down list. |
 | Add a Cylinder | Click to add cylinder from geometry drop down list. |
 | Add a Polygon | Click to add polygon from geometry drop down list. |
 | Import a Geometry | Click to import a geometry from 3D CAD file. |
 | Rename a Geometry | Click to rename a geometry sections |
 | Copy a Geometry | Click to copy a geometry sections |
 | Delete a Geometry | Click to delete a geometry section. |
 | Merge a Geometry | Click to merge geometry sections |
 | Replace a Geometry Part | Click to replace geometry with alternative one. |
 | Add a Motion | Click to access Motion drop down list. |
 | Add Linear Translation | Click to add linear translation to geometry. |
 | Add Linear Rotation | Click to add linear rotation to geometry. |
 | Add Sinusoidal Translation | Click to add sinusoidal translation to geometry. |
 | Add Sinusoidal Rotation | Click to add sinusoidal rotation to geometry. |
 | Add Conveyor Translation | Click to add conveyor translation to geometry. |
 | Add Conveyor Rotation | Click to add conveyor rotation to geometry. |
 | Rename a Motion | Click to rename a Motion. |
 | Copy a Motion | Click to copy a Motion, this can be applied to the current geometry or an alternative one. |
 | Delete a Motion | Click to delete a Motion. |
 | Move Motion Up | Click to reorder Motion. |
 | Move Motion Down | Click to reorder Motion. |
 | Add Force | Click to add force to geometry |
 | Add Torque | Click to add torque to geometry |
 | Add Factory | Click to add a material factory to the simulation. |
 | Import Factory | Click to import a factory. |
 | Rename Factory | Click to rename factory. |
 | Copy Factory | Click to copy factory. |
 | Delete Factory | Click to delete factory. |
 | Change Factory | Click to change from static to dynamic factory. |
 | Add Material Block | Click to add a material block to a geometry |
 | Delete Material Block | Click to delete a defined Material Block |
 | Show Scale Grid | When displaying particle shapes show/hide grid. |
 | Show Origin | When displaying particle shapes, show origin and particles as a mesh. |
 | Highlight Surface/Meta-Particle | Highlights selected surface of particle shape or selected Meta-Particle |
 | Add Meta-Particle | Click to add a Meta-Particle. |
 | Rename Meta-Particle | Click to rename a Meta-Particle. |
 | Copy Meta-Particle | Click to copy a Meta-Particle. |
 | Delete Meta-Particle | Click to delete a Meta-Particle. |
Note that in addition to the icon system there are a series of keyboard shortcuts shown alongside the Creator Tree for the same actions as the icons. The Delete key also can be applied to single and multiple selections.
            Show Particles: Turns the particle display in the Creator on or off.
Themes: Show the EDEM interface with Legacy Theme (default) or Dark Theme.
Split the EDEM view window into multiple displays, this allows multiple viewer windows to review different view-points of the model in each window.
The Data Browser is an .html page that displays detailed information about your model. The information displayed differs between the Creator, Simulator and Analyst. Right click in the Data Browser and choose Save to save the information in an .html file. There are five sections in the Data Browser within the Creator:
The description as defined in the Project section of the Creator Tree.
Gravity: Details of the gravity acting in your model as specified in the Creator Tree.
Materials: A list of all materials used in the model and their properties, as specified in the Materials Editor.
Energy: The total energy in the model at the current time. It is the sum of the kinetic energy, potential energy and the energy in any contacts taking place.
Domain: The dimensions of the domain as specified in the Creator Tree.
Sections: Each section is the model and its properties are listed.
Geometry Totals: Totals. Details of the number of elements that make up each section of geometry.
Particles: A list of each particle type used in the model and their properties. This contains either sphere data for Multi-Sphere, Sphero-Cylinder data or mesh data for polyhedral particles.
Factories: Details of each factory used in the model and their properties. Properties are as specified in the Creator Tree. The total number of particles created by each factory is also listed.
Particle Totals: The total number of particles in the model at the current time. Totals for each particle type are also listed.
Interactions: A list of the interaction types taking place in the model as specified in the Materials Editor.
Contacts: Lists the total number of contacts in progress at the current time. The contacts are broken down into contact types: For example number of particle A - particle B contacts or number of particle B - surface A contacts. The total number of collisions that have taken place during the time step are also listed.
Bond Totals: Lists the total number of bonds, total number of intact and broken bonds and number of bonds intact/broken between particle pairs.
| (c) 2022 Altair Engineering Inc. All Rights Reserved. | ||
