The Creator is used to setup and initialize your model. It is where you or import particles and geometries and define the other model parameters.
An overview of the EDEM Creator
Set the simulation title and a description of the simulation.
The Bulk Materials section is used used to define the material in the simulation.
Creator Tree-Equipment Material
The Equipment Material section is used to define the geometry material in the simulation.
The Geometries section is used to define the equipment and the equipment motion.
The Physics determine how particles behave in the simulation.
The Environment tab is where the simulation space is defined. This includes periodic boundaries, gravity and the simulation domain.
| (c) 2022 Altair Engineering Inc. All Rights Reserved. | ||
