Equipment materials vary from Bulk Materials in that they do not have an associated particle shape or size distribution. Bulk Materials can also be assigned to Factories; however, Equipment Materials can only be assigned to Geometries.
To add an Equipment Material to a model:
 icon to add the material. Rename the material as appropriate.
 icon to add the material. Rename the material as appropriate.You can also choose Copy Material to create a duplicate of the currently selected material. To remove a material from a model, select the material then click the  button.
 button.
Interactions must be defined with Bulk Materials and Equipment materials. To define an interaction between two materials:
| (c) 2022 Altair Engineering Inc. All Rights Reserved. | ||
