Show, Hide, and Isolate
Show, hide, and isolate objects in the modeling window using keyboard shortcuts.
To Do this Note
Show/hide selected objects
  • Press H.
  • Right-click the selection in the modeling window or Model Browser, and then select Hide Selected from the context menu.
You can also show or hide objects by:
  • Clicking their icons in the Model Browser.
  • Using the show and hide options in the right-click (context) menu.
  • Activating the Show/Hide tool in the view controls.
  • Using the View menu.
Isolate selected objects (parts, assemblies, sketches and reference entities)
  • Press I.
  • Right-click the selection in the modeling window or Model Browser, and then select Isolate from the context menu.
Isolating an object zooms in and temporarily hides all other objects.
Show all/hide all objects
  • Press A.
  • Right-click an object in the modeling window or Model Browser, and then select Show All or Hide All from the context menu.
Reverse the selection
  • Press R.
  • Right-click the selection in the modeling window or Model Browser, and then select Reverse Selected from the context menu.
Temporarily turn selected parts transparent Hold down Ctrl.
Show/Hide Mode
Use the Show/Hide tool located in the view controls to change the visibility of objects.
  1. In the view controls, click the Show/Hide tool.
  2. Choose from the following options:
    To Do this
    Hide Click the object.
    Show Hold down Shift while clicking the object.
    Hide all Double-click empty space.
    Show all Hold down Shift while double-clicking empty space.
    Tip:
    • The mouse cursor indicates whether the object you click will be shown or hidden .
  3. Right-click to exit the tool.
Objects that are hidden don't appear in the modeling window but are still included in all calculations such as optimization, static weight calculations, mass computations, etc.
