Function Definitions
Define functions using the function keyword.
| 0 inputs | 1 inputs | N inputs | |
| 0 output | function myfunc() | function myfunc(in) | function myfunc(in1, …, inN) |
| 1 output | function out=myfunc() | function out=myfunc(in) | function out=myfunc(in1, …, inN) |
| N outputs | function [out1, …, outN]=myfunc() | function [out1, …, outN]=myfunc(in) | function [out1, …, outN]=myfunc(in1, …, inN) |
The name of the function (myfunc in this case) must be a valid identifier.
After the declaration comes the function body. This is a list of statements that will be executed when the function is called. A function is terminated by the end keyword.
function halve(a)
      a=a/2
endThis function has no
        effect. It divides the local variable a by 2, but this change is not
        propagated outside of the function. (To do this, see the global keyword.) Variable names (input or output) are also unique to the function. A single variable name can be used by multiple functions without conflict.
Input variable values are re-initialized at each function call. Any local variables created in the function are released when the function ends. They are then recreated at each subsequent function call. To have local variable values retained between function calls, see the persistent keyword.
function z=myfun(a)
      z=a-1
end
y=myfun(3) % y will have a value of 2function b=factorial(a)
      if a==1
         b=1
      else
         b=factorial(a-1)*a
      end
endIf a function is defined in its own file, the final (and only the final)
          end is optional.
