Quick Access Toolbar
The quick access toolbar is a small toolbar that gives quick access to actions that are often performed.
The toolbar is located at the top-left corner of the application window, just below the title bar. It allows you to create a new model, open a model, save a model, undo a model operation or redo a model operation using fewer mouse clicks for a faster workflow. The actions available on the quick access toolbar are also available via the ribbon.
