Defining a Far Field Request
Create a far field request (0°θ≤90°, with 0°ϕ≤360°). Sample the far field at θ=5° and ϕ=5° steps. The far field request is added to the default configuration, StandardConfiguration1.
myFarField = myProject.Contents.SolutionConfigurations[1].FarFields:Add(0, 0, 90, 360, 5, 5)
myFarField.Label = "FarField1"
Figure 1. A far field request is added to the model.
  1. A far field request is a object and since there may be multiple objects in the model, it is part of the FarFieldCollection.
  2. Search for FarFieldCollection in the Help1.
  3. In the Help, under FarFieldCollection > Method List, search for methods that are applicable to adding a fra field request:
    • Add (properties table)
    • Add (starttheta Expression, startphi Expression, endtheta Expression, endphi Expression, thetaincrement Expression, phiincrement Expression)
    • Add3DPattern ()
    • AddHorizontalCutUVPlane ()
    • AddRequestInPlaneWaveIncidentDirection ()
    • AddSquareGrid ()
    • AddVerticalCutUNPlane ()
    • AddVerticalCutVNPlane ()
    To create a far field request, we will use the method:
    Add(starttheta Expression, startphi Expression, endtheta Expression, endphi Expression, thetaincrement Expression, phiincrement Expression)
  4. Fill in the θ and ϕ values and increments:
  5. Determine the syntax to prepend to Add:
    1. Since Add is a method, it is indicated by prepending a “:” (colon).
    2. In the Help, under FarFieldCollection > Usage locations (collections), note that the following objects contain the FarFieldCollection collection:
      SolutionConfigurations(.FarFields)2
      Since we know that Contents is one of the top levels in the configuration tree, the result is:
      Contents.SolutionConfigurations.FarFields:Add(0, 0, 90, 360, 5, 5)
      But we also know that a far field request is added per configuration, the result is then:
    3. Since the project is the highest level, we prepend our reference to the project:
  6. Add a reference to the newly created far field request:
  7. Set the far field request label to Source1:
    Tip: View the FarField (object) in the Help for a short example.
Feko Scripting and API Reference Guide
1
The API is available in the (PDF) or Feko WebHelp.
CADFEKO
2
The part that is prepended to the method, maps to the model tree structure.
