Requesting Far Fields
Add a far field request (in the azimuth direction) to the model.
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers a left-handed circular polarised GPS patch antenna on a finite substrate.
The example considers the antenna placement of a GPS patch antenna on a quadcopter.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
Calculate and maximise the gain of a bent dipole in front of a plate. Optimise the dipole-plate separation distance and the dipole bend-angle.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
There are several options available to launch CADFEKO in Windows.
There are several options available to launch CADFEKO in Linux.
Define variables to create a parametric model.
Create the bent dipole using a polyline.
Create the plate with a vertical orientation located at the origin using a rectangle.
Voltage sources and discrete loads are applied to ports and not directly to the model geometry or mesh. A port must be defined before a source or load can be added.
Specify the frequency range of interest. For this example a single frequency point is used.
Add an optimisation search to maximise the maximum gain in the azimuth direction.
Specify the optimisation parameters. Choose from existing variables and specify their minimum and maximum values
Specify the goal focus, the operations to perform on the goal, and the goal objective.
When the frequency is set or local mesh settings are applied to the geometry, the automatic mesh algorithm calculates and creates the mesh automatically while the GUI is active using default mesh settings. When required, these mesh settings may be modified.
Save the model to a CADFEKO.cfx file.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Open POSTFEKO from within CADFEKO.
This example showed the construction and optimisation of a bent dipole in front of a plate.
