Terminology
The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions to get a better concept of these definitions.
Dataset
A dataset is any multi-dimensional data that can be used to define a full set of quantities over a full set of axes.
Slice
Slicing gives you control over which section / subset of the data is viewed.
Trace
A trace is a line plotted on a graph that represents a quantity relative to an independent axis. The styling of the trace as well as the representation of the data can be manipulated.
3D Result
A 3D result is any data that displays in three-dimensional space.
