Probabilistic and DOE Overview
Panels that can be used to perform studies with variable inputs and multiple solver runs. Probabilistic is a powerful way to investigate effects of modeling inputs on the results. Multicase is a simple method of performing multiple runs with exact inputs supplied by the user. This Multicase creator panel only sets up the multicase run table. The “Run Model” is where the table is read, and the runs performed.
