Material Identification
Flux provides a unified Material Identification tool based on the Altair Compose environment allowing to run an identification of the coefficients required to create material in Flux.
Introduction
- Non-linear magnet described by Hc and Br module;
 - Isotropic analytic saturation + knee adjustment (arctg, 3 coef);
 - Isotropic hysteretic, Jiles-Atherton model;
 - Isotropic hysteretic, Preisach model described by 4 parameters of a typical cycle and
 - Isotropic hysteretic, Preisach model identified by N triplets.
- LS model and
 - modified Bertotti model.
- How to run the Material Identification tool.
 - Using the Material Identification tool.
 - Specificities of the identification models.
Please note that this Material Identification module - for the moment - is exclusively available on Windows machines.
In Flux Supervisor, at the bottom left part of the window, the button Material Identification allows the user to launch the provided tool dedicated to the parameter identification of a magnetic material model (either in the case of a B(H) property and of an a posteriori iron losses model).
Please remark that the Material Identification module requires the Altair ComposeTM environment to be executed. Consequently, the user must install both Altair FluxTM and Altair ComposeTM on his computer to perform a material identification with this tool. Both programs are available for download at Altair One.
- click on the Supervisor's Options button and then select Coupled software under Access paths.
 - then set the Compose environment script path to the file Compose.bat in the Compose installation folder. The path to this file should be similar to Compose_Installation_Folder\Compose\ in the case of a standard installation.
Figure 1. Flux Material Identification panel after a successful startup.
For most of the materials models in the Flux Material Identification tool, the identification consists of a 3-step procedure. The general workflow is described below:
- Step 1: After choosing a specific type of B(H) magnetic property or an iron losses model, the Flux Material Identification tool will ask the user for a file containing magnetic measurements representing the behavior of the material subjected to identification. The input data required by the Flux Material Identification tool is given by a .csv or a .xlsx file containing magnetic measurements. The file content and format depend on the specific kind of model being identified, as detailed in the next section.
 - Step 2: Once the file is correctly loaded, the identification algorithm
                    launches automatically and finds the best model parameter set fitting the
                    selected model. The results are displayed automatically in the graph window, as
                    shown in Figure 2  below. The red lines represent the reconstructed behavior provided by the
                    identified model, while the blue lines correspond to the source measurement
                    file. Depending on the model, the user may consider adjusting the parameters
                    iteratively with the sliders on the left side of the panel.
Figure 2. B(H) curves displayed using the analytic saturation + knee adjustment (arctg, 3 coef) model. In red , the fitted B(H), with the identified parameters appearing on the left side of the panel. The source B(H) measurements are shown in blue. - Step 3: Another feature of this panel is the possibility to export the pyFlux command containing the identified model parameters of the material under identification. This export is achieved by clicking on the button Save pyFlux. The pyFlux command will be directly printed in the Compose console and may be copied and pasted in Flux's console, leading to an automatic creation of the material in a Flux project. This action also creates a python file containing the pyFlux command at the same directory where the measurements are located. With the help of this file, the material may be alternatively created in a Flux project by clicking on : Project > Command file > Run a python file.
In the previous section, a general workflow for the utilization of the Material Identification tool was presented. However, since the B(H) properties and iron losses models addressed by the tool are all different, specific remarks apply for each identification case.
For the Non-linear magnet described by Hc and Br module model, the input file must contain the magnet's B(H) curve (2nd and 3rd quadrants) and be provided either in .csv or a .xlsx formats. Two columns are required in the file: the first for the magnetic field H in amperes per meter and the second for the magnetic flux density B in teslas. An example input file is available here.
In the case of the Isotropic analytic saturation + knee adjustment (arctg, 3 coef) model, the input file containing B(H) data has the same file format described in the previous paragraph, but represents instead the anhysteretic curve or the first magnetization curve of the material. An example input file is available here.
For the hysteretic B(H) properties Isotropic hysteretic, Jiles-Atherton model; Isotropic hysteretic, Preisach model described by 4 parameters of a typical cycle; and the Isotropic hysteretic, Preisach model identified by N triplets, the required file must describe a complete B(H) hysteresis loop . The formats of the .csv or .xlsx file remain similar to the others mentioned above. An example file is provided here.
In the case of the LS model, the Material Identification tool will launch a dedicated tool called MILS, with its specific identification workflow. To perform an LS model identification with MILS, please refer to this documentation chapter.
